About OpenStudio 1.0.7
What It Is
Is mainly a geometry editor for EnergyPlus. It enables you to create a building geometry from scratch: add thermal zones, draw heat transfer surfaces, draw windows and doors, draw shading surfaces, etc.
Enables you to open EnergyPlus input files, whether or not they were drawn with the plugin, and begin to make geometry changes: modify zones, delete surfaces, add new surfaces, etc.
Enables you to work with the daylighting-related input objects Daylighting:Controls and Output:IlluminanceMap. You can also add people, lights, electric and gas equipment, infiltration rates, ventilation, and ideal loads air systems so you can quickly have a running simulation starting from scratch. You can learn more about these under New Features on the Release Notes Page.
What It Is Not
Is not yet a full-featured interface for EnergyPlus. It will help you create some nongeometry EnergyPlus objects, but you will still need to work with the EnergyPlus IDF file outside of SketchUp. To effectively use EnergyPlus with the plugin, you will still have to be willing to learn about building simulation and work with the low-level EnergyPlus syntax of the text input file.
Is also not a translator from SketchUp to EnergyPlus. You cannot use the plugin to convert an old SketchUp model into an EnergyPlus input file unless you consider how to divide your building into thermal zones. To use the plugin as intended, you must have the energy model in mind as you create your EnergyPlus model. Some of the tutorials cover workflows for converting existing models to EnergyPlus input.
Conventions
In SketchUp, every object you draw on the screen is called an entity. Entities include groups, faces, and edges. These terms are consist with the SketchUp documentation, which a veteran user will recognize.
The EnergyPlus Input Data File (IDF) is also composed of objects. An EnergyPlus input object is a block of text with data values separated by commas and terminated by a semicolon. Allowable values for each field of the object are defined by the Input Data Dictionary (IDD). The InputOutputReference.pdf file in the EnergyPlus documentation provides details about the meaning and impact of each field of each object.
Conclusion
OpenStudio makes it easy to enter geometry data for your EnergyPlus input files—a task that was once both difficult and time consuming. This release also begins to add support for nongeometry features of EnergyPlus. We expect to expand access to these in future releases.
Before you start, we recommend you look at the known issues. If you have problems, feedback, or questions about the plugin, see the troubleshooting on the Release Notes page.
Thanks for reading, and good luck with all your EnergyPlus endeavors. We hope you find the OpenStudio plugin useful.
正在琢磨中,期待达人教程。本插件为开源插件。在官网注册获得密码下载,我的密码是Y6kPL1,不知别人是否能用,安装包上传115,不能用的话自己去官网注册下载,很简单的。
官网地址:http://openstudio.sourceforge.net/
115:http://115.com/file/c29ao3od#OpenStudio-1-0-7.exe
独立完整版也请官网下载,功能比SU-Plugin版的功能多。
2012龙年春节团拜纪念邮新秀奖
hf1212 2012-3-8 12:46:07
Y6kPL1是安装密码~~每个人去注册下载给的安装密码都是一样的~~
一叶刀虫 2012-3-8 14:13:21
我习惯用ecotect了 更专业些
90
Tyburn 2012-3-8 18:14:07
与ecotect的最大区别就是,ecotect是商业软件,功能强,价格也强。。。。OpenStudio则是开源的,真正免费,另外就功能而言真没差太多,反倒是ecotect有些功能稍显累赘了。
zdjdevil 2012-3-8 20:58:36
研究中···共同分享~
83
2012龙年春节团拜纪念邮新秀奖宝石收藏家热心助人奖
baoyingzhou 2012-3-8 22:10:25
哈哈谢谢分享虽然不做建筑 但以后肯定会用到
21
jazzthink 2012-3-9 12:17:34
59
l64631778 2012-5-20 22:14:47
TY版主发几张分析之后的效果,看看,哈哈
16
tov1 2012-6-7 10:01:50
啊哈,这个是什么?
多拉Da梦 2012-12-6 21:42:30
这个具体用出来时什么样的
多拉Da梦 2012-12-6 22:01:32
安装上了怎么用啊,呼唤楼主啊
lxyeden 2013-5-9 11:10:07
很不错。谢谢分享
忠实粉丝社区微博达人积极讨论奖
dai025dai 2013-5-20 03:47:31
弄来研究研究~·
借点时间5 2016-3-18 16:25:53
求安装包。[email protected],谢谢
Tyburn
