Hi my friends, I read some tut from team Lumion and have good some thing, ans I want to share for you some 360 sky I tested perfect to change background sence in Lumion.
- The first you download this file and update in your folder library and scenes ( //My Documents\Lumion in winxp)
http://115.com/file/bhfjhe2y#
Lumion.rar
- After update, you run lumion and open this scense:
you will see that:
Select no sunlight and select Edit material
Click in the Sky, select textures, and change Diffuse texture
Select a texture from my library i share for you, or other your texture
And this is some Results:
@@Note: You should used 360 texture and have ratio 4:1; example : 4096:1024 ....
And this is my library 360 sky, I want to share for you:
http://115.com/file/cltklybj#
Panor_360_skies.rar
http://115.com/file/dn0wnrgc#
sky.rar
http://115.com/file/dn0wnnkl#
360_Skies.rar
asasa
lxd-121 2011-10-9 01:23:41
见过此帖,一个国外的SU网站,org域名的。
2012龙年春节团拜纪念邮积极讨论奖
ldb1014 2011-10-9 09:02:03
試一下  su模內必須先置 sky  方可置換
92
都一把年纪了
wankehuohuayuan 2011-10-9 10:01:21
Thanks for you bring us such usefull things
149
J·Z·玩家
supesc 2011-10-9 16:54:22
看不懂啊,得去好好学习英语了{:soso_e105:}
sxbug 2011-10-9 22:32:30
why normal scense can not change the sky texture?
How can I do in normal scense to change sky texture?
核心会员热心助人奖新秀奖优秀创意奖优秀技术奖
xuanbach1985bk 2011-10-9 23:11:21
@sxbug, I forget something when to say for you, after update  in your folder library and scenes ( //My Documents\Lumion in winxp). link http://115.com/file/bhfjhe2y#
in your library will have object Dome_NoFloor, you must import it in your project and change your sky @@, look some this picture  :
sxbug 2011-10-10 07:58:35
Yes , Thanks
I want to Know what effects the other object:floor , dome?
maybe floor: change floor?
xuanbach1985bk 2011-10-10 09:16:51
You can try other scenes blackbackground and whiteTerrainandsky you will understand it. Sometime when you need create a scenes with all is white or all is black ....
I share 3 object; Dome ( include dome in sky and floor ) ; Dome_nofloor ( only dome in sky not floor ) and Floor_fordome ( only floor when you need change some texture for it)
sxbug 2011-10-10 12:35:18
Thanks
I will try it
huaxs 2012-2-26 16:40:12
很好啊,英文有点纠结~~~~
xuanbach1985bk
