Hi every one, I want to share for you the way to Creat Tree Library for Lumion from SpeedTree, My english not good,
i will show you by image @@
The first you must have soft speedtree V5.1 and used it to creat a tree ( you can see tutorial about it in youtube)
I will show the way to export to Lumion and compile them to Library Lumion
Step and Step follow this Image ( this is link mediafire if you dont see
http://www.mediafire.com/?3fhd3czpkk0rqnx   password:  xuanbach1985bk  )
After creat a tree by speedtree you export as mesh
Select output is *.fbx ( very important )
choose parameter same This image
Open Lumion, choose Flat Terrain , step and step follow images:
import file .fbx you creat from speedtree
Choose button Move object to scale it
After that select object by click button modify object - selection - select
Hold Ctrl and click in the thumbal of tree ( very important )
Ok, open compile of soft speedtree and comple follow images
Copy file .Lib.inn (71Kb) from your mydocuments/Lumion/Library (winxp @@)
change the name of file ***.Lib.inn to ***.srt.inn same to name of file ***.srt when you compile
That all !!!
asasa
影月和风 2011-8-22 10:44:39
VERY GOOD! THANKS!
禁止发言
erikonline 2011-8-22 13:48:26
提示: 作者被禁止或删除 内容自动屏蔽
yrxjjj 2011-8-24 13:43:34
Oh my dear dear friends!
a小菜 2011-9-22 02:01:43
正需要啊 谢谢啊
宝石收藏家
efengice 2011-9-23 20:18:39
Great Tutorial ! Thank you very much!
271487975 2011-10-19 17:11:08
哇哇哈哈哈哈哈哈哈这个我喜欢 厉害极了
29
zhouui 2016-6-8 16:21:49
这贴好早,贴主还在没?留着学习ST备用!
范学有 2018-9-8 01:55:12
谢谢!分享!
xuanbach1985bk
