Quadspinner Sunbeams (VUE日光制作教程)
Sunbeams capture the attention of everyone. Whether they appear thru menacing skies over the vast ocean or rolling prairies, or signal the descent of the sun through a dense forest. During those fleeting moments, Godrays often elicit a hush in the onlooker. The name alone speaks of the presence of a higher power.
In 3D, Godrays infuse the same impact into a scene, sometimes foreshadowing the hero's drama and ultimate victory. However, achieving realistic results digitally can be tricky, as specific conditions are required.
QuadSpinner's Dax Pandhi has received accolades for his development of dramatic Godrays with physically accurate world-scale. We are eager to share this collection of 4 scenes, each showcasing different moods created by this special atmosphere. We encourage you to treat these scenes as a set - the basic location upon which you, as Director, can build, create, expand.
With this collection, in addition to learning how to create Godrays without needing clouds, you receive:
Intense yet soft Godrays, with varying coloration and times of day
Optimal Godray atmospheres that you can take apart and study
Proven Godray render settings that create smooth, noiseless shafts of light
Aerial Perspective (AP) for accurate realism: in each scene AP is set to 1.00, using a scale of 1:1 for the atmosphere
在这个教程里, 你除了会学到不添加云层创建Godrays特效之外还将学到以下内容:
强烈并柔和的Godrays效果, 不同的时段不同的色彩.
里面包含最佳的Godray大气你可以分析研究学习.
经过大量测试得到的Godray渲染设置以达到平滑很少噪点的效果.
写实效果得Aerial Perspective大气透视 (AP)值: 每一个场景AP值都为 1.00,  atmosphere大气使用1:1的比例规模.
下载教程 • How to download官方信息:http://www.cornucopia3d.com/purchase.php?item_id=9088
下载地址:
http://www.filesonic.com/file/16 ... beams_Vue_112_1.zip
或者
http://bitshare.com/files/3cj7c7 ... _Vue_112_1.zip.html
或者
http://www.fileserve.com/file/MvxSRnf
gfdolly
