之二:用Render Progess窗口检查贴图
光盘上拷出来的模型,先不管三七二十一渲染一下,之前,先修改一下渲染参数,把Global Switches(全局开关)—Render(渲染)下面的Show progress window(显示处理窗口)钩上,大师们通常是不钩的。
(如果跑不下去,检查一下渲染参数,是不是原先保存的发光贴图、灯光缓存、渲染输出存盘路径等等与本机实际不合——当然不合了)
在渲染处理窗口中,注意检查类似下面的信息,窗口太小看不清就拷贝到记事本里看:
Bitmap file "C:\Users\Alim\AppData\Local\Temp\258985-035-embed.jpg" loaded.
Bitmap file "C:\Users\Alim\AppData\Local\Temp\3Fbr7MCNGHF9gyg0IwC9new.jpg" loaded.
Bitmap file "C:\Users\Alim\AppData\Local\Temp\258923-002-embed.jpg" loaded.
Bitmap file "C:\Users\Alim\AppData\Local\Temp\24490431.jpg" loaded.
Bitmap file "C:\Users\Alim\AppData\Local\Temp\muwen.jpg" loaded.
Bitmap file "C:\Users\Alim\AppData\Local\Temp\l061ye.jpg" loaded.
Bitmap file "C:\Users\Alim\AppData\Local\Temp\dz-mh04.jpg" loaded.
Bitmap file "C:\Users\Alim\AppData\Local\Temp\1793816-1291729-jinhw8-embed-embed.jpg" loaded.
Bitmap file "C:\Users\Alim\AppData\Local\Temp\youmu04.jpg" loaded.
Bitmap file "C:\Users\Alim\AppData\Local\Temp\10462401.jpg" loaded.
Bitmap file "C:\Users\Alim\AppData\Local\Temp\Saucer.jpg" loaded.
Bitmap file "C:\Users\Alim\AppData\Local\Temp\7179.jpg" loaded.
Bitmap file "C:\Users\Alim\AppData\Local\Temp\003.jpg" loaded.
Bitmap file "C:\Users\Alim\AppData\Local\Temp\wangwen01.jpg" loaded.
Bitmap file "C:\Users\Alim\AppData\Local\Temp\mupfel2.jpg" loaded.
Bitmap file "C:\Users\Alim\AppData\Local\Temp\galliumL.jpg" loaded.
Bitmap file "C:\Users\Alim\AppData\Local\Temp\frontplaza.jpg" loaded.
Bitmap file "C:\Users\Alim\AppData\Local\Temp\200511811342024233.bmp" failed to load: cannot open file
Bitmap file "C:\Users\Alim\AppData\Local\Temp\mupfel1.jpg" loaded.
Bitmap file "C:\Users\Alim\AppData\Local\Temp\mupfel3.jpg" loaded.
Bitmap file "C:\Users\Alim\AppData\Local\Temp\32944679.jpg" loaded.
如果全部Loaded,万幸!如果有 failed,就说明贴图有错,要小心了。 |
