New Features:
V-RayRT - a revolutionary new rendering engine that provides instant feedback and streamlines scene setup. Because V-RayRT is built upon the same robust core as V-Ray, it is seamless to transition between the two.
Dome Light -provides a simple, artifact-free solution for creating image based lighting. Its powerful importance sampling analyzes HDR images to optimize light tracing and GI precision.
V-Ray Proxy - indispensable tool for managing scene memory and efficiently rendering massive amounts of geometry. V-Ray Proxy objects are dynamically loaded and unloaded at render time, saving vital RAM resources.
Lens Effects (Glare / Bloom ) - simulate the natural lens effects that occur when photographing highlights.
Dispersion - provides the ability to trace and refract light based on its wavelength, creating even more realistic results.
Retrace Threshold - reduces Light Cache artifacts and improves the appearance of glossy reflections and refractions when using the time-saving feature - Use light cache for glossy rays.
Ambient Occlusion - generates shading based on an object’s proximity, making it an effective solution for enhancing GI details without significantly increasing render time.
VRayDirt - simulates shading around corners and crevices of objects based on a radial distance. VRayDirt can be used to produce a variety of effects, including ambient occlusion renderings.
Interpolation (Reflections and Refractions) -accelerates rendering by approximating and caching the effects of glossy reflections and refractions.
IES Light - uses photometric data to provide accurate light definition.
Sphere Light - adds a spherical area light to the V-Ray 1.5 for Rhino toolset.
Additional Parameters such as roughness for diffuse BRDFs, along with exit color and max. depth for reflections and refractions, provide new levels of control when creating materials in V-Ray 1.5 for Rhino.
Improved Rhino Integration
V-Ray 1.5 for Rhino supports the RDK Sun and can be used in conjunction with the VRaySun/ Sky system.
V-Ray 1.5 for Rhino supports the 32 and 64 bit versions of Rhino 5.0. as well as the 32 bit version of Rhino 4.0
官网:http://www.vray.com/
顺便吐槽隔壁恶心的速度,20m带宽像龟爬!没吧币没等级,各位大侠行行好给点辛苦费吧。。{:soso_e109:}
吧里没找到资源,有的话版主就删了吧。
下载地址如下:
亲爱的SketchUp吧会员,此内容需要进行付费查看,您需要支付1个吧币 立即购买
林健想 2013-8-30 11:47:57
我也来抢一个。
missonline 2013-8-30 11:48:35
感谢感谢。。!
youto 2013-8-30 13:15:34
感谢感谢。。!
忠实粉丝社区微博达人积极讨论奖
dai025dai 2013-8-30 13:20:00
膜拜下楼主~~等待XX{:soso_e142:}
uyushu 2013-8-30 17:27:40
试试看。这不是正式版吧?
uyushu 2013-8-31 14:57:44
这次ies终于能亮了,虽然需要设置比较大的值。1.6完全不亮。。。
含紫忧兰 2013-8-31 15:45:13
没有红宝石的孩子伤不起  怎么能得到红宝石哇···楼主这个和supp兼容不》需要注册码么
含紫忧兰 2013-8-31 15:46:28
uninitialized constant VRayForSketchUp::VfSEntitiesObserver加载文件错误 vfs.rb
  我装的时候出现了这个是怎么回事
含紫忧兰 2013-8-31 15:53:02
为什么我一点开m就崩溃?
含紫忧兰 2013-8-31 16:01:46
楼上的好心人 可以发一个安装包给我么???我的QQ邮箱642982228,
含紫忧兰 2013-8-31 17:02:34
谢谢 楼上的大好人 万分感谢
含紫忧兰 2013-8-31 17:03:03
话说这个 不是试用版吧?可以一直用吧
uyushu 2013-8-31 17:11:17
含紫忧兰 发表于 2013-8-31 17:03
话说这个 不是试用版吧?可以一直用吧
安装包有点大哦100m,发邮件上传很慢
含紫忧兰 2013-8-31 17:15:01
嗯 谢谢······很好用 比1.49好 这个不是试用版啊 可以一直拥塞 ?你的eQQ好多嘛 以后可以交流一下
uyushu 2013-8-31 17:19:12
QQ:654531241,我也是在学习v-ray中,欢迎交流!
90
宝石收藏家新秀奖热心助人奖忠实粉丝
pclong 2013-8-31 18:07:15
感谢感谢。。!
tao1015 2013-8-31 22:30:55
来看看。。
喵.Another 2013-9-1 22:01:35
什么都不知道先回复
34
cslrlyc 2013-9-3 22:01:55
非常感谢~~~
1234下一页
missonline
