http://ext.makenewsmail.com/read/29412/44570446/4980
ACT-3D 公司於今天發佈了 Lumion 3.1 更新版本,同時提供部分功能受限的 Free Edition 免費版本下以及新的 Lumion Viewer 程式下載訊息.
現有 Lumion 3.0 版本用戶將收到免費更新通知,請依提示進行下載安裝即可.
Lumion 3.1 加入了新的執行偵錯功能,以及顯示目前電腦設備的執行效率,作為改善硬體資源的參考;支援對Google Earth (KMZ)檔案的匯入功能等。詳細的新增與改進內容如下:
New Fuctionality
  • New Lumion Viewer released (Press Enter to toggle between Flythrough and Movie mode).
  • New Lumion Free 3.1 released.
  • New DirectX diagnostics output function for error reports.New Lumion Benchmark function.
    KMZ files from Google Earth can now be imported in Lumion.
    Lumion can now load LS3 files from Lumion Pro.
Improvements
  • Optimization breakthrough when importing or re-importing models: Up to 50% more efficient models than in previous versions of Lumion!
  • Animated 3D people now feature better lighting and increased texture sharpness.
  • Theatre mode now includes effects when viewing an LS3 file.
  • LS3 files are now almost 100% self-contained (only Clip type -> Movie is not included in LS3 files).
  • Memory usage is now more efficient when you load new scenes with imported models in them (In previous versions, the total memory usage could increase, the more scenes you loaded in a session)
  • The Global Illumination effect now includes a separate editor for assigning GI to individual spotlights.
  • The intensity of specular highlights on wet terrain has been reduced.
  • When model icons are overlapping you can no longer use the mousewheel to toggle between them (use the Arrow up/down keys instead).
  • The license activation server has been moved to the Windows Azure Cloud.
  • Info option: Verts and k (for 1000) have been made more readable for humans.
  • New ‘Safe’ mode when you press the Escape key (a mode where you can’t accidentally do stuff).
  • Advanced Move mode (Now F12 key) has been renamed to Free Move mode.
  • Glass material: Overbright slider was removed as other materials are better suited for glow effects.
Changes and Resolved Errors
Build Mode
  • Trees & Plants: Vertex animation is now working again.
  • Keyboard shortcuts are no longer active while editing a Layer name.
  • Lumion terrain edges are now longer cropped before reaching 2048×2048 meters.
  • Orbit function no longer ignores trees while in Advanced Move mode (Escape key).
  • Spotlight -> Edit Properties -> Target Light function no longer ignores trees.
  • Photo mode -> Build with effects -> Focal length is now transferred to Build mode.
  • Trees can now be moved in Advanced move mode (Escape key).
  • Target Light function now includes trees in collision check.
  • Light gizmo height indicator of selected lights no longer changes height when moving a different light.Terrain: Tile size slider is no longer too long when opening certain scenes.
  • Using the mouse scrollwheel in file dialog windows no longer makes the camera move.
  • Build with effects: Depth of Field effect no longer results in landscape brush artifacts.
  • Trees/plants now snap correctly to the terrain when the ocean is just below the terrain.
  • Languages: Selection Count text is now displayed when using non-English language.
  • Languages: Tooltips are now displayed correctly when using non-English language.
  • Replace with Library Selection: Spotlights no longer turn into inverted spheres.
Material Editor
  • Material names are now case-sensitive, so ‘Brick’ and ‘brick’ will result in 2 different materials.
  • Video textures are now limited to a maximum file size of 50MB per file.
  • The Depth offset slider range has been reduced to prevent excessive values.
  • CTRL + Reload model button is now a disc button.
  • Water material: Color density slider is no longer reversed.
Photo Mode And Movie Mode
  • Video texture: The last frame in a video texture is no longer played as the first frame in a rendered clip.
  • Image sequence: Tree/plant animations are no longer out of sync every time you re-load a scene nd render a frame range again.
  • Advanced Move effect: Models are no longer moved to 0,0,0 when all of their keyframes have been eleted.
  • Advanced Move: Deleting the last keyframe now only affects the selected object.
  • Advanced Move: Scale is now working properly for imported models again.
  • 3D silhouettes are now visible in planar reflections.
  • Damping has been reduced for thumbnail navigation in Edit clip mode.
  • Using the G key no longer accidentally flushes the buffer.
  • Reflection effect: 3D silhouette people are now reflected correctly.
  • Edit clip mode: Left/right arrows work more consistently now.
  • Escape tooltip is now displayed as an option while rendering.
  • Double-clicking on the Trashcan icon in Edit clip mode no longer makes the interface disappear.
  • Entire Movie -> Move effect -> Models no longer move too fast and finish before the movie is over.
  • Sky Alpha, Lighting and MaterialID custom maps have been fixed and/or improved.
  • Horizon clouds should no longer flicker if you place the camera high above the terrain.
  • Motion Blur effect now works correctly under water.
  • Depth of Field effect is now working under water.
  • Reflection effect: Specular highlights from spotlights are now smaller by default.
  • Depth of Field effect: Blur leaking reduction slider has been removed.
  • Shadow effect: Range has now been renamed to Sun shadow range.
  • Reflection effect: Error Reduction is now called Flicker Reduction.
  • Cloud effect: Cloud control is now called ‘Position’.
  • Volume Clouds effect: Seed is now called Position.
  • Cloud effect: Slider names have been split up in Low and High clouds.
Sound
  • Clip type -> Movie no longer prevents background music/sound from being played.
  • User-imported background sounds no longer pans when the camera turns.
  • Sounds no longer continue to play when on a hidden Layer.
Miscellanious
  • Template and demo scenes have been overhauled (There are more to come).
  • AMD driver version 13.10 no longer causes a Not the same error in Lumion.
  • Clicking on In use effect thumbnails no longer opens the Lumion Pro website page.
  • Object circle icon of the native Lumion water plane has been fixed.
  • New tooltip when trying to delete imported model files that were used in a recent scene.
  • Textures of distant 3D animated people are no longer blurry.
  • Load scene -> Surrealistic shader effect while loading has now been disabled.
  • Lumion 3/Miscellaneous folder -> External video/sound files are now copied to the new Video
  • extures and Sound folders.
以下是我在Goole中直译
发布新Lumion浏览器(按下Enter键来切换之间的切换和电影模式)。
新Lumion免费3.1。
新的DirectX诊断为的错误reports.New Lumion基准功能输出功能。
从谷歌地球KMZ文件现在可以导入Lumion。
Lumion现在可以加载Lumion专业的LS3文件。
改进
优化突破时,导入或重新导入模型:高达50%的效率模型,而不是在以前版本的Lumion!
三维动画的人提供更好的照明和增加质感的清晰度。
剧院模式现在包括查看LS3文件时的效果。
LS3文件,现在几乎100%的(唯一的剪辑类型 - >电影LS3文件中不包含)。
现在更有效的内存使用情况是当你打开新的场景与进口车型(在以前的版本中,总内存使用量可能会增加,更多的场景,你装在一个会话)
全局照明效果,现在包括一个单独的编辑器分配GI个人聚光灯。
在潮湿的地面镜面高光的强度已经减少。
当模型图标是重叠的,你可以不再使用鼠标滚轮在它们之间切换(使用向上/向下箭头键来代替)。
通过许可证激活服务器已经转移到Windows Azure云。
信息选项:绿党和K(1000)已对人类更具可读性。
新的“安全”模式下,当你按下Esc键(一个模式,你可以不小心做的东西)。
先进的移动模式(F12键)已更名为自由移动模式。
玻璃材料:其他材料更适合于发光效果Overbright滑块被删除。
改变和解决错误
构建模式
木和植物:顶点动画是现在的工作了。
键盘快捷方式不再有效,在编辑图层名称。
Lumion地形的边缘,现在不再裁剪之前达到2048×2048米。
轨道函数不再忽视的树木,而在高级移动模式​​(Escape键)。
射灯 - >编辑属性 - >目标照明功能已不再忽视的树木。
照片模式 - >效果 - >焦距现在转移到构建模式的构建。
树可以移动先进的移动模式(Escape键)。
现在的目标光功能包括树木碰撞检查。
轻小发明高度指标的选择灯不再改变高度移动不同的light.Terrain时:瓷砖大小滑块不再太长时打开某些场景。
在文件对话框窗口中使用鼠标滚轮不再相机移动。
建立与效果:景深效果不再景观刷文物。
树/植物捕捉正确的地形,海洋正下方的地形。
语言:选择计数的文本时使用非英语语言显示。
语言:当使用非英语语言的工具提示现在可以正确显示。
更换库选择:投光灯不再变成倒球。
“材质编辑器”
材料名称是区分大小写的,所以'砖','砖',将导致2种不同的材料。
视频纹理现在只有50MB的每个文件的最大文件大小。
已减少的深度偏移滑块范围,以防止过度的值。
CTRL +重载模式按钮现在是一个圆盘按钮。
水材料:彩色密度滑块不再转回。
照片模式和电影模式
视频纹理:不再演奏作为渲染的剪辑中的第一帧的最后一帧中的视频纹理。
图像序列:树/植物的动画不再是不同步的,每次重新加载场景ND再次提供的框架范围内。
先进的移动效果:模特们不再移动到0,0,0时,其所有的关键帧已eleted。
高级移动:删除最后一个关键帧现在只影响所选的对象。
高级移动:规模现正为进口车型。
3D轮廓是现在可见的平面反射。
阻尼编辑剪辑模式的缩略图导航已经减少。
使用G键不再意外地刷新缓冲区。
反光效果:3D剪影人现在可以正确反映。
编辑剪辑模式:左/右箭头现在更一致。
现在,逃生工具提示显示为一个选项,而渲染。
编辑剪辑模式不再垃圾桶图标上双击,使界面消失。
整部影片 - > Move效果 - >模型不再移动太快,之前完成的电影是。
天空阿尔法,照明和MaterialID的自定义地图已经固定和/或改善。
地平线云不再闪烁,如果您将相机高高的地形。
运动模糊效果现在正确地在水中。
现正根据水的景深效果。
反光效果:镜面高光射灯默认情况下,现在变小了。
现场效果:模糊泄漏减少滑块的深度已被删除。
阴影效果:范围已更名为孙影的范围。
反光效果:减少错误,减少闪烁。
云效果:云控制是现在所谓的“位置”。
现在被称为体积云效果:种子位置。
云效果:滑块名被分割在低和高云。
声音
剪辑类型 - “电影不再阻止从正在播放的背景音乐/声音。
用户导入的背景声音不再平移打开相机时。
听起来不再继续玩的时候隐藏图层上的。
Miscellanious
模板和演示的场景已大修(有更多的惊喜)。
AMD驱动程序版本13.10不再会导致一个不一样的错误,Lumion。
不再使用效果缩略图点击打开的Lumion Pro网站页面。
对象圆圈图标的原生Lumion水平面已得到修复。
新的工具提示当试图删除导入的模型文件,在最近的一次现场。
遥远的3D动画人的纹理不再是模糊的。
加载场景 - >超现实主义着色器效果,而现在被禁用加载。
的Lumion 3/Miscellaneous文件夹 - >外部视频/声音文件复制到新的视频
extures和声音文件夹。
yigehaobb 2013-3-28 22:45:48
有更新了啊
破解的呢?
破晓之风 2013-7-27 21:21:46
{:soso_e117:}破解何时才会出现呢
bogesoho 2013-7-31 08:49:58
想要和谐的,有吗?
qqsaver 2013-8-9 10:28:22
给力的~
l123liang 2013-8-27 21:11:59
謝謝分享
grs432
