TrueTangents v1.2
功能1:通过辅助点和已知圆或圆弧,添加点到圆的正切辅助线。
功能2:通过已知的两个圆或圆弧,添加之间的正切线。
This Ruby provides two functions - 'truetangents' and 'commontangents' - it has plugin-menu items or type the names to run it from the Ruby Console. It's written to work on a selection BUT could be reconstructed as a cline method if thought useful...
truetangents
Select an arc/circle and a cpoint (aka guide-point)
Run truetangents
On errors - e.g. no arc selected or the cpoint is inside the circumference - there is a console message.
It then draws cpoints at the arc centre and tps, and clines on the two radii and tangents - it draws to the true tps - these might not be on the arc itself if it's lightly segmented - now you can rotate, entity-info increase segments or reconstruct the arc as desired so it passes through a tp...
commontangents
Select a second arc/circle
Run commontangents
On errors - e.g. 2 arcs not selected or a circle within another circle can have no common tangents - there is a console message.
It then draws cpoints at the arc centres and tps, and clines on the four radii and two/four tangents - it draws to the true tps - these might not be on the arc itself if it's lightly segmented - now you can rotate, entity-info increase segments or reconstruct the arc as desired so it passes through a tp... Different forms of common tangent are produced if the arcs are separated by clear space or intersect (4 or 2 nr)...
jpg
jpg
TrueTangents.rar (1.46 KB, 下载次数: 88)
TrueTangents.rar
1.46 KB , 吧币: 200 , 请登陆后再进行下载!
SUAPP3.4
kksky 2009-5-30 13:22:00
好工具 呵呵
23
yangguoshe 2009-5-30 13:39:00
感谢楼主共享!!!
zh_6531394 2009-7-5 15:53:00
怎么用的?
leixing
