Lumion 2.2.1 Ultimate
Lumion 2.2.1 Ultimate | 2.8 GB
Lumion 2 will take visualization indoors by providing quick and easy tools for indoor visualization. The updated architecture visualization software lifts visuals to a new level by providing several essential new features.
Lumion produces images and video for visualisation. Rapidly. High quality output, suitable for client presentation, produced in minutes not hours, and in hours not days. Lumion provides a productive, highly focused realtime 3D environment for the creation of visualisation scenes rapidly. A simple import and update workflow is used to bring content through to Lumion. The Lumion real-time 3D environment is where a user completes the building of the scene, such as adding in terrain, sky and weather settings, scene objects, lighting, and other 3D content. Scenes can then be rapidly rendered to still image, or video animation to create high quality visualisation content.
Users can also provide direct presentation in realtime to clients. This is a truly fantastic tool for rapid visualisation and ease of workflow. This tool can fit into a visualisation pipeline/workflow to provide time savings and quality output. Lumion is already proving an invaluable time saver and hit with a growing number of architects and others in visualisation. It is being successfully used to provide more cost effective visualisation content to clients.
With the 3D rendering software Lumion, it has never been easier to create architectural visualizations of your 3D models. Simply add water, trees, people, cars and amazing weather effects, and render awesome videos in minutes. Or present the scene to your client as a real-time 3D fly-through. Faster and easier than ever before.
Used As A Visualisation Tool For:
- Architecture
- Construction Planning
- Infra-structure Planning
- Building Projects and Developments
- Property Design
- Landscape Design
Some Features:
- Realtime interior lighting (V2).
- Ability to handle large scenes, with optimisations of large to massive polygon models and texturing to provide best case real-time playback and rendering for stills and video.
- Import your models from most DCC and CAD tools, supports leading industry Collada and FBX formats, as well as Max, 3DS and Obj.
- Use terrain templates, create terrains, or import your own.
- A weather system with cloud, fog, simple sun positioning, sunlight shadow. Create areas for water, as well as an amazing ocean add-on.
- A range of add-ons are available, providing additional content and effects (refer illuminate3d.com or the Lumion® web site).
- Simple, intuitive, constant and rapid improvements, supportive and dynamic architectural and visualisation based professional community and forum.
What’s new in Lumion Ultimate 2.2
New Features
New models and high quality trees & plants (227 in total).
New landscape materials.
Updated Revit to Collada exporter.
Terrain materials can now be combined any way you like.
You can even import your own terrain textures.
New Copy-Paste and Save/Load options for Standard materials.
More workspace Layers (Maximum 20 Layers instead of 5).
New clip keyframes export option in Photo mode.
New background rendering mode so you can check your emails while it’s rendering.
Other Changes & Impoverements
New “Insert new photo” button which will replace (CTRL) + (C) in the Clip editor.
User-configurable names for Layers.
New “Move Selection to Layer” button.
Smoother people & animal animations.
Improved “wet” effect for Lumion terrain.
New custom scale for Lumion terrain materials.
New Extra Color slider in Fountain properties.
New color palette option for Fog color selection.
It is now possible to change the pitch and bank values of 3D people.
CTRL + H: Reset camera pitch to horizontal viewpoint.
New keyboard shortcut: L -> Scale
New keyboard shortcut: P -> Rotate Pitch
New keyboard shortcut: B -> Rotate Bank
Bug Fixes
Terrain culling is now turned off when rendering.
F9: Max level of detail for Trees/plants is now turned on correctly.
3D Silhouette people and animals can now use transparency and shadows again.
Renderings of the ocean now look more like the preview in Build mode.
Saving a scene under a new name now works correctly again.
Violent wind gusts have been turned off.
Movie thumbnails are no longer black after loading a new scene.
CTRL + SHIFT + Left-click no longer requires 2 clicks before an object is selected.
Animated objects can now use more than 1 material.
Photo mode -> Motion Blur is now working.
Space command no longer swaps objects in the process.
Show/hide Layer states are now saved correctly.
Trees -> Rotation snap is now working.
Trees -> Context menu -> Transformation -> Same rotation now works correctly.
Trees -> Context menu -> Transformation -> Lock Position is now working correctly.
Act3D-BV:
Lumion is developed by Act3D-BV, the team who developed Quest3D, a proven real-time 3D authoring tool that has been a leader in the marketplace for over 8 years, and used for many real-time 3D visualisation projects. Through their direct association with many architectural clients and projects, and their Quest3D customer base, Act3D have a solid reputation in providing high performance real-time 3D solutions.
Home page: _http://lumion3d.com
Download Links:-
http://extabit.com/file/27ay38ixl1tgv/Lumion.v2.2.1.Ultimate.Incl.Patch.part1.rar
http://extabit.com/file/27ay38ixl1tin/Lumion.v2.2.1.Ultimate.Incl.Patch.part2.rar
http://extabit.com/file/27ay38ixl1thb/Lumion.v2.2.1.Ultimate.Incl.Patch.part3.rar
http://extabit.com/file/27ay38ixl1zv3/Lumion.v2.2.1.Ultimate.Incl.Patch.part4.rar
http://extabit.com/file/27ay38ixl22y7/Lumion.v2.2.1.Ultimate.Incl.Patch.part5.rar
http://extabit.com/file/27ay38ixl1tfj/Lumion.v2.2.1.Ultimate.Incl.Patch.part6.rar
http://extabit.com/file/27ay38ixl0unz/Lumion.v2.2.1.Ultimate.Incl.Patch.part7.rar
请翻墙下载,或者转换地址后下载,或者用国外网盘下载利器下载。
w125922340 2012-5-26 13:31:53
太慢了  还是很感谢楼主啊
人走茶就凉 2012-5-26 13:47:00
在等专业版的破解
32
忠实粉丝
mmmjyet 2012-5-26 14:26:09
谢谢,您是怎样破解的交流一下破解经验。
2012龙年春节团拜纪念邮新秀奖
hf1212 2012-5-26 14:32:29
不知道怎样翻墙下载~~{:soso_e103:}
yrxjjj 2012-5-26 14:58:42
给个翻译么,不懂!
22
新秀奖宝石收藏家积极讨论奖
美丽坏男孩 2012-5-26 15:53:31
不是吧  旗舰版都破解啦,意思全部的功能都能用上了  打包功能等等都能用上了吗?希望楼主能详细地解析一下,,下载不了为什么?    给楼主您加宝石了,,,
linli7795 2012-5-26 17:32:01
厉害啊!下下来看看
lusheji 2012-5-26 18:12:47
厉害啊 楼主感谢你的分享 {:soso_e179:}
Treecko 2012-5-26 19:31:19
希望LZ提供以下单纯的破解文件~安装原文件还是直接官方下载比较快~不过还是感谢LZ分享~o(*≧▽≦)ツ
qazxcvb30125 2012-5-26 20:16:44
是绿化版吗
sunxiadi 2012-5-26 21:18:35
美丽坏男孩 发表于 2012-5-26 15:53
不是吧  旗舰版都破解啦,意思全部的功能都能用上了  打包功能等等都能用上了吗?希望楼主能详细地解析一下 ...
旗舰版只是基础版,专业版才有所有功能
luluxiu 2012-5-29 19:43:00
sunxiadi 发表于 2012-5-26 21:18
旗舰版只是基础版,专业版才有所有功能
不是旗舰版最牛吗,例如win7系统??
luluxiu 2012-5-29 19:44:20
问下楼主发的是lumion2.21原版和破解器吗?都包括什么?
sunxiadi 2012-5-31 01:06:20
luluxiu 发表于 2012-5-29 19:43
不是旗舰版最牛吗,例如win7系统??
从2.2开始专业版是最贵的
yilin3366 2012-6-1 23:35:03
楼主你好  我目前需要建大的场景  这个能帮助我实现么  就这个是不是渲染速度上有提高  谢谢楼主了
云儿 2012-6-4 21:50:39
好好学软件~~~~~
黑皮0313 2012-6-5 01:10:01
楼主牛人啊 谢谢楼主
ftyx_lulin 2012-6-5 10:37:33
谢谢楼主
38
宝石收藏家忠实粉丝积极讨论奖
山東男孩 2012-6-5 10:43:37
传说中的升级,好快啊?我们会不会跟不上更新的步伐啊??更新的那么快 就怕软件变化太大,不好系统化学习。 这次更新解决了输出场景和演示,这个真的太重要了。跨时代的进步
12下一页
zld20016983
