is a ruby based program that will create a grid pattern of omni lights in your model. The goal is to create a uniform source of lights without using LEMs or without over-populating your model with omni lights. Select a face or several co-planar faces (such as a ceiling, wall or floor). Right click your mouse for the context menu. Select OmniGrid. Then select the grid distance from the dialog box and click OK. You can also Flip the Omni Grid if it does not display where you expect it. An Omni Grid group will be created. The group will be populated with the same component which contains a single omni group. The default light value of the omni group is 4 and color gray with opacity set at zero. You can change the light value and other properties of the entire grid, simply by changing the properties of one omni light in the grid. You can also move the omni grid position.
简单的说,这就是个一个布置矩阵点光源的插件
jpg
jpg
OmniGrid.zip
31.22 KB , 吧币: 200 , 请登陆后再进行下载!
OmniGrid.zip
31.22 KB, 下载次数: 403, 下载积分: 吧币 -200 个
zip
DesigNet刀 2009-5-21 16:30:00
顶楼主!!!
谢谢~~~
忠实粉丝Sketchup建模大赛 第四期 TOP5
yuxinzhi12 2009-5-22 03:20:00
放哪个文件夹?
phofun 2009-5-22 05:57:00
原帖由 yuxinzhi12 于 2009-5-22 3:20:00 发表
放哪个文件夹?
通常是 plugin
liaoye 2009-5-22 10:52:00
我放置进去了,打开软件没看到,到底是怎么用啊,楼主是否可告知,多谢
135
hadron 2009-5-22 12:50:00
谢谢分享!!:D
jmsht0516 2009-5-22 18:01:00
还要再研究研究·
98
Rank: 10Rank: 10Rank: 10
sm501212 2009-5-22 18:41:00
podium的資源很少:-!
難得的插件謝謝!
arch5 2009-6-11 17:38:00
下载了,然后放到插件中,可打开软件在哪儿呢?没看到什么呀.
leonpu 2009-6-11 22:06:00
顶楼主!收下了
k0079 2009-6-22 23:42:00
放在plugin即可
接著對您想製做矩陣光源的面(face)
按滑鼠右鍵可看到"Greate OmniGrid "選項
yzy1101 2010-1-10 20:55:24
确实布灯是个麻烦事
21
onlyyong 2010-1-15 17:22:25
SU里自带一个命令“X”,可以复制的
先选择,用移动工具按住CTRL键复制一次,然后直接键盘输入Xn,n就是你想复制的数量。
复制后,再选择一行,可以再次复制
zhangnet 2010-1-16 20:48:36
非常实用感谢楼主分享
52
plf_10 2010-4-4 00:35:02
是啊
哪位能解释一下楼主发的插件和这样操作有什么区别 ?:-_^
ddhvdf 2010-4-4 14:48:35
我有个问题想问问,为啥podium在对群组会出现选取失败的情况的?
886622 2010-4-6 14:11:10
不会用,请楼主上详细说明,谢谢哈
tony28 2010-5-10 11:57:30
啊啊啊啊啊啊啊啊啊啊啊啊啊啊
kenlovedesign 2010-6-15 11:27:30
有這東西~太好了~感謝大大分享
mianfeideyu
