  • Version: 2.5.2.34-g5152a41
    • Released: 2019-05-16T08:30:23.4087676Z
    • Changelog:
      • Reduced memory usage by downsampling large textures
      • Fixed wrong orientation of keyframes/views when two-point perspective is active
      • SketchUp: Fixed objects behind glass are black with active section plane
      • Some other bugfixes
  • We’ve just released our official 2.5.2 hotfix::
    • Fixed objects behind glass are black with active section plane      (Sketchup)
    Lots of smaller bugfixes:
    • Mirror, metal and frosted keywords not working in Rhino &      Archicad
    • Enscape does not write Log Files in Revit 2020
    • Cannot run standalone executables with vc++ redistributable      2015-2019
    • Opacity map and emissive does not work as expected
    • Can't render image in ArchiCAD if Enscape Settings window is open
    • Metallicness can be configured for transparent surfaces
    • .ico file cannot be loaded in Revit but in other CADs
    • Asset Placement broken in Archicad teamwork projects
    • Can't disable the video editor from the CAD while editing a      keyframe
    • Camera Paths with keyed ToD invert sun angle randomly
    • Wrong transformation unit in Rhino material editor ui
    • Archicad customization settings crashes
    • No visual indication when asset data cannot be downloaded from      server
    • Archicad asset placement - missing early out/guard in parameter      access
    • Various crashes
我们刚刚发布了官方的2.5.2热修复::
•通过向下采样大纹理减少内存使用
修正了两点透视时关键帧/视图的错误方向
•玻璃后面的固定物体是黑色的,带有活动剖面图(Sketchup)
许多较小的错误修复:
•镜子、金属和磨砂关键词在Rhino & Archicad中不起作用
Enscape在Revit 2020中不写日志文件
•无法运行独立的可执行程序与vc++可重新分发2015-2019
•不透明度地图和发射不像预期的那样工作
•如果Enscape Settings窗口打开,则无法在ArchiCAD中呈现图像
•金属度可配置为透明表面
•.ico文件不能在Revit中加载,只能在其他CADs中加载
•Archicad团队项目中出现的资产配置问题
•在编辑关键帧时,无法从CAD禁用视频编辑器
•相机路径与键控ToD反转太阳角度随机
•Rhino材质编辑器ui中的转换单元错误
•Archicad定制设置崩溃
•当资产数据无法从服务器下载时,没有可视化指示
•Archicad资产配置-在参数访问中丢失早期out/guard
•各种崩溃
ENSCAPE超级讲吧原创教程
tas_1985
