We hope that you are enjoying Lumion.
Lumion Free has now been updated and a brand new version is available for download. You'll need to register in the Lumion forum and click on "Customer Area" in order to download the new installer:
http://lumion3d.com/forum/
Download and unpack the .ZIP file in a temporary directory, and run the setup file.
You can keep older versions of Lumion installed without problems.
Some of you have already taken the plunge and upgraded to Lumion Basic or Lumion Ultimate. People like you make it possible for us to continue to add new features and improvements to Lumion, so we're grateful for your support.
If you have any questions or would like to share your work with the rest of the community, we'd love to hear from you in the Lumion forum.
The Lumion Team
___________________________________________________________
Here are some of the improvements in the new version of Lumion Free:
You can now place objects a lot further away from the center of your scenes.
If you press F9, all trees and plants in the viewport will be rendered at their best level of detail, so that it's easier to see where you need to add more trees and plants in a scene.
Camera animations are now smoother than before, and ambient occlusion shadows (SSAO) have been improved.
The "baking" process which optimises rendering performance for many identical objects is now a lot faster and uses far less memory.
A new "Show Layer" effect with keyframes has been added, so that you can show the different stages of the construction of a building in a single clip.
Edge smoothing in movies has been dramatically improved thanks to a new "Smooth edges" effect which will be replacing the old "MLAA" effect. This effect is ideal for rendering movies in 2-star mode if you haven't got time for the more costly x16 edge smoothing in 3-star mode.
Please check out the attached ChangeList_LumionFree.txt for a detailed list of changes.
附上下载地址:http://download.lumion3d.com/5E0 ... mionFree_SP2_B7.zip
Enscape官方许可证团购
庄主
过故人庄 2011-9-1 10:51:45
我们希望你喜欢Lumion。
现Lumion免费更新,已有一个全新的版本可供下载。你需要在Lumion论坛注册,点击“客户专区”,以下载新的安装程序:
下载并解压缩。ZIP文件中的一个临时目录,并运行安装文件。
您可以继续安装了旧版本的Lumion。
你们当中有些人已经采取暴跌和升级Lumion基本或Lumion终极。人们喜欢你使我们有可能继续增加新功能和改进,以Lumion,所以我们对您的支持表示感谢。
如果您有任何疑问或想分享您的工作与社会的经验,我们非常欢迎你到Lumion论坛告诉我们。
下面是一些Lumion免费的新版本的改进:
现在,您可以将物体很多远离中心的场景.
如果你按F9,将在视口中所有的树木和植物,呈现在他们的最佳细化效果,使其更容易地看到,你需要在场景中添加更多的树木和植物。
摄像机动画现在比以前更顺畅,并已改善环境遮挡的阴影。 【这个更新的很重要】
“渲染”的过程中,许多相同对象的优化渲染性能是现在快了很多,并使用少得多的内存。
已经添加了新的“显示层”关键帧的效果,这样您就可以显示在一个单一的建筑物建设的不同阶段;
在电影的边缘平滑已经显着提高到一个新的“边缘平滑”的效果将取代旧的“MLAA”的效果。这种效果是理想的2星级模式呈现电影,如果你没有得到时间更昂贵的X16三星级模式平滑的边缘。
请检查附件的详细清单
谷歌翻译,修改了一些不通畅的地方。
zhouchi527 2011-9-1 13:37:09
刚装上,貌似是64位的,我64位系统
书战翊函 2011-9-2 07:35:03
厉害!强~~~~没的说了!
kekex 2011-9-2 08:03:53
1.场景面积扩大,现在可以把模型放在距离中心点很远的地方了(这点我遇到过,模型距离中心很远的,渲染的图,地面有问题,模型无法插入,只能移动了)
2.按F9可以在当前视角将所有树木以最佳效果显示,以便方便查看哪些地方需要更多绿化
3.相机拍照效果更加平滑,SSAO效果和效能提升
4.增加关键帧显示图层功能(干嘛的?)
5.视频编辑特效提升巨大,替换掉原来的MLAA(3星效果模式)
禁止发言
erikonline 2011-9-2 08:07:23
提示: 作者被禁止或删除 内容自动屏蔽
张羿 2011-9-2 21:22:20
楼主真了不起,感谢了!
禁止访问
华芬颖高 2011-9-6 02:20:47
提示: 作者被禁止或删除 内容自动屏蔽
feng445536 2011-11-24 12:50:07
many many thanks
feng445536 2011-11-24 12:53:13
这个只有450m是完全版吗?
lumion一般不是有2.8g左右吗?
宇航员 2011-12-2 10:31:48
楼上的,这是个升级补丁
禁止发言
sufang0183h 2011-12-17 20:48:14
提示: 作者被禁止或删除 内容自动屏蔽
六月缤纷 2011-12-19 21:40:22
不知道是哪一步不对装不上~~我是初学者~~
huanglilin 2012-1-4 02:54:06
楼上的,貌似你要先安装原版
liumye
