原文http://lumion3d.com/forum/index.php?topic=1764.0
Dear Lumion user,
亲爱的Lumion用户,
Lumion Service Pack 2 Build 6 is now available for download in the Customer Area.
Lumion Service Pack 2 Build6 现在顾客区已经可以下载。
Download and unpack the .ZIP file in a temporary directory, and run the setup file.
下载并解压ZIP到临时路径中,启东安装程序。
You can keep older versions of Lumion installed without problems.
新版本可以和旧版本很好得共存。
We recommend that you create a backup of your Library and Scene files before using the new build (they are located in the Documents/Lumion/Scenes & Library folders).
在使用新版本前我们推荐您备份Library和Scene文件夹(位置Documents/Lumion/Scenes & Library)
About Service Pack 2 Build 6
关于 Service Pack 2 Build 6
Numerous bugs have been fixed, camera animations are now smoother than before, and as some of you saw in the forum, ambient occlusion shadows (SSAO) have been improved quite a lot.
我们修复了众多bug,镜头动画更加平滑,同时正像有些人已经在论坛看到的一样,SSAO有了巨大的提升。
The "baking" process which optimises rendering performance for many identical objects is now a lot faster and uses far less memory.
因为优化了相同物件的渲染性能,出图速度大大提升,同时占用更少的内存。
A new "Show Layer" effect with keyframes has been added, so that you can show the different stages of the construction of a building in a single clip.
增加了用于关键帧的新的图层显示效果,现在您可以在一个剪辑文档中展示建筑的建造全过程。
Edge smoothing in movies has been dramatically improved thanks to a new "Smooth edges" effect which will be replacing the old "MLAA" effect. This effect is ideal for rendering movies in 2-star mode if you haven't got time for the more costly x16 edge smoothing in 3-star mode.
动画中抗锯齿也有了极大的提升,因为一种新的平滑显示效果代替了原来的MLAA。新的抗锯齿两星的模式中尤为显著,特别是当您的小电脑在三星模式的16倍抗锯齿下不太给力的时候。
We have also added a bunch of lovely new palm trees, corals, water lilys and grass objects to the Tree Pack which should make your scenes look more realistic than ever.
我们同时也在植物包里增加了一些很萌的棕榈啦,珊瑚啦,睡莲啦,草啦,相信它们会让您的场景前所未有得真实。
Thanks to all of you for your continued support and encouragement - we hope to bring you even more exciting features and improvements in the future.
谢谢你们一如既往的支持和鼓励,我们会持续给您带来激动的新功能与提升。
All the best,
此致敬礼
The Lumion Team
Lumion团队
不过FREE版本暂时还没更新,但是马上会出的
可能会是这个链接,现在还不能用http://download.lumion3d.com/LumionFree_Sp2_B6.zip
Enscape官方许可证团购
庄主
过故人庄 2011-8-18 10:57:06
没有室内灯光系统的更新,一切的更新都是画蛇添足
禁止发言
erikonline 2011-8-18 11:33:43
提示: 作者被禁止或删除 内容自动屏蔽
ceavorton 2011-8-19 09:20:41
不错,增加了很多新元素,新植物和水草。不过就是比以前更加梦幻了。反正对于景观已经很好了。
135
hadron 2011-8-19 10:34:32
更新得好快啊!刚把B5搞下来还没装,B6已经出来了
Treecko 2011-8-19 12:30:34
翻译得好萌~~>。<
核心会员共享精神奖
14141301 2011-8-19 15:44:44
刚装完B5,浮云啊~
热心助人奖新秀奖忠实粉丝积极讨论奖
鸭了个梨 2011-8-19 16:34:27
暂时使用free  很满足
等有了 再把植物拷贝过来  嘿嘿~~~
congchien 2011-8-19 17:09:50
NO DOWN LOAD
迅鸟瞰雷 2011-8-23 06:24:54
真是好人啊~~
sxbug 2011-8-23 20:58:01
很不错啊
congchien 2011-8-23 23:51:12
please download file
congchien 2011-8-23 23:52:12
application files for download
hzwcy 2011-8-24 11:38:21
更新变化很大
宇航员 2011-12-2 10:38:22
是啊,一直没有室内灯光的IES,啥也没有啊
25
ce1001 2011-12-19 22:32:55
刚入手一个低版本的 ,也期待可以有室内空间的实现方式,先 熟悉下吧,看上去功能不错
zeroun
