RE: 跪求指导~~!!
It is a example, hopefully it is helpful. And slao you'd better to do some research in this bar, there are alot threads talking about how to build a curvy surface, like 老怪's threads.
1-draw 3d curves based on your design
2- use extrusion tools
3- extrude edge by rails
first, pick the profile
second, pick the first and second rails
then, pick the merge profile...
later on, you will get the surface. if there are any dialogs appears just select' no'
use soften edges to build nicel looking faces.
then, repeating to get all surface...
here is the plugins....
extrudeTools_20100517.zip
(138.04 KB, 下载次数: 47)
