Maxwell Render 2.5 – with FIRE
Next Limit is pleased to announce the release of Maxwell Render version 2.5.  This free update for Maxwell Render 2.x clients includes many exciting improvements and new features.  These include:
  • New Maxwell Fire interactive technology  - available inside plug-ins and Maxwell Studio
  • Sub-Surface Scattering improvements in both quality and performance
  • Numerous workflow improvements including new scripting functions, new command line options and parameters, and networking improvements especially for running animations.
  • As well as many other fixes and improvements
                          The most significant new feature in version 2.5 is Maxwell Fire – Fast Interactive Rendering.   Maxwell Fire is an interactive tool which provides instant results while setting up a scene.   Now Maxwell Render users can preview scene lighting and materials in seconds.  And unlike other interactive style render solutions, Maxwell Fire IS:
  • Compatible with ALL Maxwell Render materials and features
  • A truly interactive workflow – integrated in plug-ins and Maxwell Studio
  • Entirely CPU based - no additional hardware required
  • No extra cost – it is not a separate add-on application, and is a free update for Maxwell Render 2.x clients.
                                The first roll-out of Maxwell Fire is in Maxwell Studio, and the plug-ins for Maya, 3ds Max,  Rhino and SolidWorks.
                (Other plug-ins will see the addition of Maxwell Fire in the coming weeks and months where possible subject to SDK limitations.)
                    The release of Maxwell Fire continues our strategy to build on Maxwell Render´s  position as the leader in render quality by adding new and innovative solutions to improve the workflow and interaction between user and render output at both pre- and post-processing stages.
GOOGLE 翻譯.......
很高興地宣布發布2.5版本的Maxwell渲染。這個免費更新Maxwell Fire
2.x的客戶包括了許多令人興奮的改進和新功能。這些措施包括:
    *新Maxwell Fire互動技術-可在插件和麥克斯韋工作室
    *子面散射改善質量和性能
    *許多工作流程的改進,包括新的腳本功能,新的命令行選項和參數,改進,尤其是網絡運行的動畫。
    *以及許多其他的修正和改進
最重要的新功能在版本2.5是Maxwell Fire-快速交互繪製。Maxwell Fire是一個互動的工具,它提供了立竿見影的效果,同時設立一個場景。現在,用戶可以預覽Maxwell 渲染場景照明和材料秒。而且不像其他互動式的渲染解決方案,Maxwell Fire:
    *兼容所有Maxwell 渲染材料和功能
    *一個真正互動的工作流程 -集成插件和Maxwell工作室
    *完全基於 CPU- 無需額外的硬件要求
    *無需額外的成本- 它不是一個單獨的附加應用程序,並且是免費的更新Maxwell渲染2.x的客戶。
第一個推出了Maxwell Fire是在Maxwell Studio和插件為 Maya,3ds Max軟件,犀牛和SolidWorks。
(其他插件會看到除了麥克斯韋消防在未來幾週和幾個月的SDK在可能受到限制。)
Maxwell Fire釋放繼續我們的戰略建立在Maxwell 渲染的領導地位在渲染質量,增加新的和創新的解決方案,以改善工作流程和用戶之間的互動和渲染輸出前和後處理階段。
官網
http://www.maxwellrender.com/fire/index.php
更新說明PDF
http://www.maxwellrender.com/pdf/featureslist-v2.pdf
下載位置:感謝會員kuangji分享
http://www.sketchupbar.com/thread-20863-1-1.html
寂寞飯糰
都一把年纪了
wankehuohuayuan 2010-12-17 18:36:20
回复 chenkl 的帖子
隔壁的管理员说这个很容易死机的,说会消耗殆尽你的cpu和显卡,所以我还是观望一下吧,毕竟这个软件速度也不是很快的那种。
137
飯糰幫
2012龙年春节团拜纪念邮优秀版主核心会员宝石收藏家热心助人奖忠实粉丝优秀技术奖荣誉会员Sketchup建模大赛 第五期 TOP5Sketchup建模大赛 第六期 TOP5Sketchup建模大赛 第七期 TOP5
chenkl 2010-12-18 00:46:25
回复 wankehuohuayuan 的帖子
隔壁的管理员说屎可以吃你就相信嗎?自己試試吧~
個人淺見:
渲染是設計的絕對嗎?
渲染器的選擇.....比不上操作者的技術
psychon 2010-12-18 15:19:33
试一下你就发现速度还是可以的
sy860131 2011-7-19 12:32:39
界面很复杂的样子
23
flyawayyu2020 2011-9-27 13:38:39
相信chenkl的推荐没错的!!{:soso_e113:}
潇风FanX 2012-10-8 02:35:35
haohaohaohaohaohaohao
chenkl
