Su podium网站更新 发布1.6beta测试版
1.6版有以下新特性
What's New in Version 1.6 Beta
Multi-threading support means faster rendering, Alpha Transparency support, Plants and Trees Library, Render All renders all SketchUp scenes in a batch (or tries to)
1.6 beta is faster....much faster.
Because Podium 1.6 now supports multi-threading, your dual or quad processors will be used during the raytracing and anti-aliasing process of the rendering. This will lead to two to three times speed increase in rendering times compared to version 1.5. The speed increases depends a lot on the number of processors your computer has and the size of the image resolution. Generally the higher the image resolution, the greater the speed difference from Podium 1.5. Cadalog, Inc. tests have seen speed differences of two to four times. However, be aware that Geometry Process, Mesh building, Photon mapping do not support multi-threading so initially when you start the render, it may not seem that the rendering is going any faster than 1.5. Once the raytracing and anti-aliasing process starts, you will notice the speed difference.
Alpha Transparency. PNG images that have backgrounds that are alpha transparency are now supported in Podium. These images can be placed in SketchUp and will render with transparent backgrounds. There is no need for clip maps anymore.
Free Plants and Trees Library
. Cadalog, Inc. has create a drag and drop plug-in for SketchUp which is comprised of dozens of components of plants, trees and shrubs. This is a web dialog based plug-in which simply allows you to drag and drop the various trees and plants. Each plant and tree image is contained in a face me component. Please download from the Registered User page. Download file size is 230 mb.
Render all scenes- batch rendering of scenes When you choose Render all scenes from the Podium menu and then click Render, Podium will render each scene in the SketchUp model. Podium only renders the scenes with a camera view. The idea behind Render all scenes is that you can use a tool like SU Animate to create a SketchUp walk thru animation. Once you have all the scenes of your SketchUp animation, Podium will render each scene and save each finished image (JPG or PNG). You can then take all the rendered images and use a program like Microsoft's Movie Maker to create a rendered animation video.
更快的渲染速度 比1.5快2-3倍
支持alpha通道 透明贴图
免费的植物组件
批量渲染所有页面
podium_16_beta3_setup.rar (1.12 MB, 下载次数: 283)
jpg
jpg
1.12 MB , 吧币: 200 , 请登陆后再进行下载!
pkhet 2008-11-9 13:09:00
Su podium网站更新 发布1.6beta测试版(提供本地下载)
值得期待哈
hcchone 2008-11-21 13:24:00
1.6beta 3測試版也更新了
另外還有樹木及燈光插件也更新了
不錯用耶!!
zis
zis 2008-11-22 10:02:00
我觉得这才是SU的风格~既小又简洁
deathdx 2008-11-22 19:23:00
请问这个有汉化版么
killwen9 2008-12-4 09:58:00
能出多大的图,还是有限制吗?
guyuelei1986 2009-4-15 21:50:00
有汉化最好的了 那有使用说明吗·······
Archi 2010-4-2 12:02:01
谢谢楼主了 :D
purplewind
