软件版本是SketchUp pro 2016, 操作系统win7
截至2016年12月15日7:23:39, 创建新的Trimble Id 网页会弹出如下提示:
HTTP Status 500 - Request processing failed; nested exception is java.lang.IllegalArgumentException: Locale part "zh-cn" contains invalid characters
type Exception report
message Request processing failed; nested exception is java.lang.IllegalArgumentException: Locale part "zh-cn" contains invalid characters
description The server encountered an internal error that prevented it from fulfilling this request.
exception
org.springframework.web.util.NestedServletException: Request processing failed; nested exception is java.lang.IllegalArgumentException: Locale part "zh-cn" contains invalid characters
        org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:973)
        org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:852)
        javax.servlet.http.HttpServlet.service(HttpServlet.java:735)
        org.springframework.web.servlet.FrameworkServlet.service(FrameworkServlet.java:837)
        javax.servlet.http.HttpServlet.service(HttpServlet.java:848)
        org.springframework.web.filter.CharacterEncodingFilter.doFilterInternal(CharacterEncodingFilter.java:88)
        org.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:108)
root cause
        org.springframework.util.StringUtils.validateLocalePart(StringUtils.java:708)
        org.springframework.util.StringUtils.parseLocaleString(StringUtils.java:688)
        org.springframework.web.servlet.i18n.LocaleChangeInterceptor.preHandle(LocaleChangeInterceptor.java:73)
        org.springframework.web.servlet.HandlerExecutionChain.applyPreHandle(HandlerExecutionChain.java:130)
        org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:932)
        org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:870)
        org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:961)
note The full stack trace of the root cause is available in the Apache Tomcat/7.0.55 logs.
好的环境能长出更多好东西.
aamoranaa 2017-12-15 23:56:50
我的也是注册不了,已注册就出现这样的页面,楼主解决了吗
136
heixing 2017-12-18 10:51:21
可能是服务器地址被土蔷的缘故
136
heixing 2020-9-9 00:46:39
最近是可以了, 。。。
heixing
