载入文件 CadalogBeamTool.rb 时出错
Error: #<SyntaxError: C:/Users/46015/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/CadalogBeamTool.rb:21: syntax error, unexpected ',', expecting ')'
...pport_file ("CadalogParts.dll", "Plugins/Cadalog")
C:/Users/46015/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/CadalogBeamTool.rb:21: syntax error, unexpected ')', expecting keyword_end
C:/Users/46015/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/CadalogBeamTool.rb:296: syntax error, unexpected ',', expecting ')'
    edges.push (beam_entities.add_line (startPt, endPt))
C:/Users/46015/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/CadalogBeamTool.rb:306: syntax error, unexpected ',', expecting ')'
...eam_entities.add_arc (centerPt, xAxis, normal, radius, start...
C:/Users/46015/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/CadalogBeamTool.rb:306: syntax error, unexpected ')', expecting '='
..., radius, startAngle, endAngle))
C:/Users/46015/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/CadalogBeamTool.rb:313: syntax error, unexpected ',', expecting ')'
    edges.concat(beam_entities.add_circle (centerPt, normal, radius))
C:/Users/46015/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/CadalogBeamTool.rb:313: syntax error, unexpected ')', expecting '='
C:/Users/46015/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/CadalogBeamTool.rb:362: syntax error, unexpected end-of-input, expecting keyword_end>
cslrlyc 2016-11-24 14:45:22
有些老插件使用以前的老RUBY写的,语法格式不严谨的话,在以前的老版本的SU上还能用,在新的SU里面已经无法使用了。
芹菜919
红宝石用户A
