原創 - Skatter For Sketchup 下载 + 破解方法
There are
two main way for the trial countdown, 1. Online server, 2. Program Date.有兩種主要方式的試用倒計時,1.在線服務器,2.程序日期。
My method is deal to the Program Date. No crack file is required, mean no risk for the virus attack.
我的方法是處理程序日期。 不需要破解文件,意味著沒有病毒攻擊的風險。
For Skatter, we will use the program called "RunAsDate v1.31" to freeze the trial time as it start.
對於Skatter,我們將使用名為“RunAsDate v1.31”的程序在開始時凍結試用時間。
By this way, we can use the plugin for unlimited long. As long as you keep freezing the trial time.
通過這個方法,我們可以
無限長地使用插件。 只要你繼續凍結試用時間。
IMPORTANT: Only use the shortcut which created by the RunAsDate. Or else, the trial will be finish immediately.
重要:僅使用由RunAsDate創建的快捷方式。 否則,試用將立即結束。
Skatter for Sketchup 下载方法:
1. Go to https://www.skatterforsketchup.com/ . Click the "Download free trial / Demo".
1. 進入 https://www.skatterforsketchup.com/ 點擊 "Download free trial / Demo"
2. Roll down to this column.
2. 向下滾動直到此列。
3. Click the "Download free trial / Demo".
3. 點擊 "Download free trial / Demo"
4. Put number "0" (Zero) in the box called "Name a fair price". Then click "I want this !".
4.在 "Name a fair price" 框中輸入數字“0”(零)。 然後點擊 "I want this !"
5. Fill the personal information. Then click "Get".
5.填寫個人信息。 然後點擊 "Get"
6. After, check your mail box. You will got such email. Click "View product".
6. 之後,檢查您的郵箱。 你會收到這樣的電子郵件。 點擊 "View product"
7. Download the version according to your PC.
7. 根據您的PC下載版本。
Done.
完成。
RunAsDate 下载方法:
1. Go to http://www.nirsoft.net/utils/run_as_date.html and roll down.
1. 進入 http://www.nirsoft.net/utils/run_as_date.html 並向下滾動。
2. Choose the version and Download.
2. 選擇版本和下載。
Done.
完成。
RunAsDate 破解使用方法:
1. Open the program.
1. 打開程序。
2. The windows should pop-up.
2. 窗口應該彈出。
2.1 Choose the Sketchup.exe intall location. Example: "C:\Program Files\SketchUp\SketchUp 2016\SketchUp.exe".
2.1 選擇Sketchup.exe安裝位置。 例子:"C:\Program Files\SketchUp\SketchUp 2016\SketchUp.exe"
2.2 Enable the box. That make the trial freeze everytime you open the sketchup.
2.2 啟用此框。 這使每次打開Sketchup凍結試用時間。
2.3 Enter the name for the shortcut, then click " Create Desktop Shortcut =>".
2.3 輸入快捷方式的名稱,然後單擊 " Create Desktop Shortcut =>"
3. After you created a shortcut. Open Sketchup with this ONLY.
3.創建面快捷方式後。 使用此選項打開Sketchup。
4. Go to the "Extensions > Skatter > Skatter" to open the for Skatter for Sketchup.
4. 轉到 "Extensions > Skatter > Skatter" 以打開Skatter for Sketchup。
5. Go to the options.
5. 進入選項。
6. Enter your e-mail to Activat. ** My one is already activated. So, there are not the same as here.**
6. 輸入您的電子郵件以激活。 **我的已經激活。 所以,這裡不一樣。**
Done.
完成。
Skatter for Sketchup 破解驗證:
1. As we see 15 days trial since Activate.
1. 正如我們看到,15天試用。
2. The email is sent at October 9, 2016.
2.電子郵件於2016年10月9日發送。
3. Today is October 11, 2016. The trial time should be 16 - 2 = 14 days.
3. 今天是2016年10月11日。試用時間應為16 - 2 = 14天。
4. Look here, it keep the trial days as 16 days. No change.
4. 看這裡,試用天保持為16天。 沒有變化。
Success.
成功。
Here you go. Enjoy.
幹得好。 請享用。
Please kindly to support.
請衷心支持。
Sorry for my poor Chinese.
因為我
差勁的中文
寫作對不起
Copyright to Chan, Teck Fai Saputra. ( Me )
Epimetheus 2016-10-17 11:44:14
thank you for your sharing
Saputra 2016-10-18 02:11:59
Feel free to ask if there is any problem.
苹果里的狼 2016-10-20 11:14:17
你好,感谢提供的这篇教程。但是,由于我提前安装试用过,现在,已经不能用这个办法了,有什么方法可以绕过15天的试用期么?非常感谢。
Saputra 2016-10-20 23:11:01
蘋果里的狼 發表於 2016-10-20 11:14
你好,感謝提供的這篇教程。但是,由於我提前安裝試用過,現在,已經不能用這個辦法了,有什麼方法可以繞過 ...
Since the Activation is through the "email-server registration system" to detect the trial time.
Changing the system time or regedit is not working in this case.
Plus, Cracking the sever is a illgel act.
Therefore, here is the best solution for you.
Is your Skatter still installed in the Sketchup plugin? Yes ->a , No->b
a- Is it activated but showing "Demo is over" ? Yes ->c , No ->d
b- Re-installed Skatter and activated with an new email. Then use the "RunAsDate" to stop the trial.
c- Deactivate the licence. Then activate with an new email. Then use the "RunAsDate" to stop the trial.
d - Activate with an new email. Then use the "RunAsDate" to stop the trial.
That's mean, the only thing you can do is -> **Create a new Demo account**
Be careful this time.
Remember ONLY use the shortcut which created by "RunAsDate" to open sketchup. Or else the demo time will run out normally.
苹果里的狼 2016-11-4 10:10:38
你好,非常感谢你的回复,让我知道如何去做。
你提供的这个方法的确可以冷冻试用时间,但是,,,重启后,skatter不会出现红色的代理框,相当于软件失灵,尽管试用时间没有减少。
非常希望探讨与你,非常开心。谢谢。
aaa31415 2016-11-4 11:09:00
谢谢 果然有效
苹果里的狼 2016-11-4 16:10:42
你好,你这个是跟楼主说的图文不符啊!你这个明显是有序列号的嘛,已经不是试用版了好吧!???能分享一下么?
aaa31415 2016-11-7 09:48:29
苹果里的狼 发表于 2016-11-4 16:10
你好,你这个是跟楼主说的图文不符啊!你这个明显是有序列号的嘛,已经不是试用版了好吧!???能分享一下 ...
我按照楼主的方法做的,然后打开su直接报错奔溃了,我重启了电脑以后又开了一下,发现变成这样了
li1213 2016-11-7 12:47:46
skatter for sketchup安装时做到第四部打开时出现了黄色对话框是什么情况?请教
songwate 2016-11-8 13:15:13
li1213 发表于 2016-11-7 12:47
skatter for sketchup安装时做到第四部打开时出现了黄色对话框是什么情况?请教 ...
更新ie浏览器安装个ie11的就好了
苹果里的狼 2016-11-8 13:54:41
楼主教的是冷冻,你这个明显PJ,序列号还给遮住了哇哈哈。有偿无常你分享出来嘛,大神别装啦
songwate 2016-11-10 16:50:45
可以使用但是生成不了植物,直接试用就能生成,不知道其他人是否也遇到这样
arch杨涵宇 2016-11-11 09:06:30
问一下 skatter按照教程破解后 就是时间冻结后 用的时候不小心点到了deactivate(因为这单词不认识,想试试,吃了没文化的亏
arch杨涵宇 2016-11-11 09:08:14
结果就gg了 然后重新申请15天的号还是没法用 重装skatter与更换su版本也没法用 都显示already triedskatter demo 感觉是这台电脑已经有用过的信息就用不了了  请问怎么能重新使用呢
work2012 2016-11-14 17:09:56
找到这里了,累啊!谢谢楼主
aaa31415 2016-11-15 16:28:21
锁时间还是突破不了15天的限制,看着试用时间还有好多天,结果不会出现红色的代理框
苹果里的狼 2016-11-18 16:19:12
songwate 发表于 2016-11-10 16:50
可以使用但是生成不了植物,直接试用就能生成,不知道其他人是否也遇到这样 ...
是的呢,握手,我也是这情况,能用,但是代理框不出现了。
艺术设计yj 2017-1-10 22:01:57
测试成功,楼主威武
123下一页
Saputra
