原廠更新至1.48.89
http://software.asgvis.com/index ... iew&gid=518&Itemid=
http://software.asgvis.com/dmdocuments/VRayForSketchUp-1.48.89-windows-installer.zip
小黑屋
忠实粉丝
allenwucat 2010-7-20 11:45:51
不是吧,这么快!tks
32
7352679 2010-7-20 11:47:52
还要破解吗?
yubaobao 2010-7-22 08:57:29
1.48.83的破解补丁用不了了,请大家试试
liaohu 2010-7-22 10:27:46
算了,也太快了吧,上个版本都还没用过。。。。。哎。。。。日新月异!!
y371704080 2010-7-22 12:52:41
一直在忙,好久没来了,没想事情发展这么快呀,又更新了!!
WZF
352
习惯一个人
WZF 2010-7-22 21:58:29
再等等吧,看样1.5快出了。。。呵呵
宝石收藏家热心助人奖忠实粉丝积极讨论奖
chizo 2010-7-23 00:29:07
小弟來Update Change Log :
1.48.89
Fixes:
- Fixed invalid output image path issue that would cause a blank render
- Fixed issue that caused our gamma settings to be ignored in the material/texture preview renders
Changes:
- Made sure that our memory map was getting closed regardless of situation
______________________________________________
1.48.88
Fixes:
- Switched over to use memory-mapped files when parsing scenes. This should make it so some of the larger scenes that previously failed to render will now work
- Glossy reflections and bump map now work together properly
- Default lights can be enabled with other lights in scene now.
- Sketchup embedded textures show in previews now
- Material picker handler doesn't pick mats if you hit cancel now.
- Fixed problem with sphere plugin that caused material previews to not show displacement properly
Changes:
- When maps are set, the button changes color to make it more obvious
1.48.87
Fixes:
- Fixed a logic error in some of the render plugin parameters that caused a memory leak
- Fixed an issue that caused the Light Cache layout to not show properly if it was both primary and secondary engine
- Fixed problem that caused importing materials to fail if the new material has a differet name than the material you were importing into
Changes:
- Added "Cast shadows" option to default material. This specifies whether or not the material will cast shadows
- Added "Only visible in secondary" option to default material. This makes it possible to have a material only show up in reflections or refractions
- Added "ID Color" to default material. This color allows you to set what color will show up in the Material ID VFB render channel
- Modified the way the "Options" panel in our default material UI looks to accomodate new options
1.48.86
Fixes:
- Fixed issue that made license utility not get launched on Leopard and Tiger OSX
- Fixed problem that could occur when all layers were removed and adding new layers would be disconnected from the material
- Made a slight modification to the Toon material that should make it so it doesn't get slower when the line width is bigger
1.48.85
Fixes:
- Fixed a problem that made it so VfS couldn't be loaded on Leopard or Tiger OSX
- Fixed issues related to the changing of installation paths for side-by-side VfS and VfR installations
- Fixed issue that could arise if you used Google's component warehouse and grabbed two components with the same name
- Fixed some issues that caused importing images to not work
- Fixed problems related to two side materials being loaded / saved into our scenes
- Fixed some issues related to our file-searching algorithm
- Fixed it so the aspect ratio lock button will be set correctly when loading scenes
- Fixed issue in DRSpawner that could cause it to render black
- Fixed a problem that made it so the UI necessary to save Photon Maps was hidden
- The file extensions for the gi maps should be filled in correctly when you go to save them out
杂了嘛 2010-7-23 09:38:14
关注一下
ufflcel 2010-7-23 17:28:22
继续观注当中,近期不打算更新,1.48.66用得挺爽的,观望中。。。。。。
ponycd 2010-7-23 20:31:33
可能用习惯了无名老师的汉化版本...都下了新的却没试用
但依然得谢楼主....:D
44
yongqinju 2010-7-25 00:47:13
一波末平一波又起,太快了跟不上,还是再等等吧。
pir1688
