重新安装显示“已安装”解决方案:
删除下面的3个注册表键。这会指示Revit已经从Windows Installer 卸载。
HKEY_CLASSES_ROOT\Installer\Products\<Product ID>
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Products\<Product ID>
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\<Product Name>
- 用完整的产品名称替换<Product Name>:
- 用对应的值替换<Product ID>:
Autodesk Revit Architecture 2012 English: 0A4B643700210110409007C5D0680240
Autodesk Revit Structure 2012 English: 0A4B643700210120409007C5D0680240
Autodesk Revit MEP 2012 English:0A4B643700211130409007C5D0680240
注意
Revit 产品的Product ID 一般以0A4..... 开头。您可以确认当前查找的是正确的注册表键,或者对于本地化版本,打开 HKEY_CLASSES_ROOT\Installer\Products\<Product ID>,检查产品名称看是否是要找的Revit对应产品。
无法正常卸载解决方案:
Revit在某些情况下可能会出现不能正常卸载(通过控制面板)的问题,这个时候即使再重新安装也安装不上,或者表面看起来安装成功,但是不能使用。这个时候可以考虑通过注册表卸载。步骤如下(之前用英文写的,懒得翻译):
Open registry editor and findfollowing key:
Under this folder, find revit build whichneeds to be uninstalled. For example,Revit 2013,as show in the following screen shot:
Double click UninstallString, Copy the value data:
Click OK. Then run cmd command, and past thecommand.
Run the command, then Revit will be uninstalled.
Use the same method to uninstall Revitlanguage package, as shown in the following screen shot:
Now Revit 2014 should beuninstalled successfully.
vmxnvit
