:D 使PNG图产生真实阴影插件_ImageProfile.rar (23.47 KB, 下载次数: 408)
descriptionAutomatically create components from image files SketchUp 6 or higher
usageImageProfilecreates components from transparent PNG image files. It includes analgorithm to trace around the image for more realistic shadows forpeople, trees, etc. Images can be oriented flat (horizontally) orvertically for creation of plan-view and elevation/perspective-viewentourage. Origin point presets are middle-bottom or center of image,with vertical offset option for plan-view objects to cast shadows, andFaceMe option for vertically-oriented objects (people, trees, etc).
  • Start a new model.  Do not run the plugin in an existing model!
  • Select "Image Profile" from the Plugins menu.  The first time you do this after downloading, you will be asked to provide your email address and to create a password (to protect your credits).  After you create a password, and on subsequent runs, this will bring up the dialog box
  • Select a PNG file to process (will be uploaded to Smustard.com for processing).  Themodel must be on your computer, or accessible through a letter-mappednetwork drive. The plugin cannot read non-mapped network locations!
  • Input an actual height for the finished component
  • Select an accuracy level (note that lower accuracy levels may cut off parts of the image during the tracing process)
  • Select an orientation (horizontal or vertical).  Following options will then be preset, but may be manually changed.
  • Click "Process"
The PNG file will be processed on our server, and the data sent back toSketchUp, where the image will be traced, sized, oriented, and saved asa component.
The lower-left corner of the SketchUp window (the status bar area) willhave information about the progress of the image processing. Mostprocessing should take just a minute, though the overall time could beseveral minutes, depending on image size and internet connection speed.
喜欢就用红宝石砸!需要连网使用吧!
23.47 KB , 吧币: 200 , 请登陆后再进行下载!
SUAPP3.4
qwertylin 2009-5-20 00:19:00
3k连这个都找到了,似乎很有用
Arc
核心会员优秀技术奖荣誉会员
Arc 2009-5-20 00:28:00
之前装过这个,插件是免费的,但是服务是要收费的。
忠实粉丝
寻道 2009-5-20 01:31:00
这个插件非常有用
但是能有破解版的么
深蓝 2009-5-20 08:44:00
XXXXXXXX 有破解没啊
36
宝石收藏家热心助人奖
kkk_163 2009-5-20 08:54:00
原帖由 Arc 于 2009-5-20 0:28:00 发表
:D哈!没搞清楚啊!好像类似的还有好几款,不过都是收费的插件呢!
23
yangguoshe 2009-5-20 10:37:00
感谢楼主!!!
kksky 2009-5-20 13:42:00
好东西啊  好人
23
yangguoshe 2009-5-20 15:17:00
我还以为是我不会用,原来是要收费
这可是个好东西
sunny789123 2009-5-29 12:47:00
ms没有XXXXX
mazhi3000 2009-11-24 23:56:04
谁破解了,我免费给他提供PNG图,无数张
我自然 2009-11-25 10:55:30
非常有用的东西,谢谢了。
小黑屋
carrottj 2009-12-16 22:26:09
居然是收费的,晕比
170102362 2009-12-18 10:03:28
下来看看  图个新鲜
princesser 2010-1-14 11:09:47
苍天呐 ~~~
yammwood 2010-3-4 08:46:51
好东东呀,支持su7吗,先谢谢楼主了
leying001 2010-3-10 16:22:57
又潜水了~类似还有什么插件可以有阴影啊
flyhgun 2010-4-10 20:26:08
楼主好人啊。
如此好的东西共享给大家。
90
Tyburn 2010-4-10 21:03:23
哎~好东西都不白来啊。。:-|
mazhi3000 2010-4-28 03:26:25
高手弄个PJ就好了
12下一页
kkk_163
