1、
Comparison between Lumion 2.5 effect picker and Lumion 3.0 effect picker.
    Lumion 2.5效果选择器和Lumion 3.0效果选择器的比较。
Lumion is powerful but easy software you can just pick up an get results with. For Lumion 3.0 we wanted to put even more emphasis on usability.
One example of this is the way you can select movie effects. In Lumion 2.5 you have to select effects by name. This makes it really hard to remember where your favorite effects are. In Lumion 3.0 we improve this on three fronts.
· We made sure there is a maximum of only 9 effect in screen at any point in time. With only 9 effects to chose from you can easily spot the effect you need.
· We made the screen bigger and have big preview shots to give a clear impression of what the effect will looks like.
· simple monochromatic icons were added so you can easily find effects even when their previews look similar.
Do you want to know how Act-3D makes sure you can use Lumion 3.0 without a manual? Curious about the redesigned environment settings? Can’t wait to see the new “Photo mode” and export options?
Act-3D will let you know everything on this blog. See you next time!
Lumion是功能强大且易于软件,你可以随便挑了一个得到的结果。对于Lumion 3.0,我们希望把更加注重可用性。
这方面的一个例子是,您可以选择电影效果。在Lumion 2.5,你必须选择效果的名称。这使得它真的很难记得你最喜欢的效果。我们在Lumion 3.0提高这三个方面。
· 我们确保在任何时间点上,有一个最大的只有9画面效果。只有9效果选择,你可以很容易地发现你所需要的效果。
· 我们做了屏幕更大,有大的预览拍摄给什么效果看起来像一个清晰的印象。
· 这样你就可以很容易地找到效果,甚至当他们的预览类似于简单的单色图标添加。
你想知道如何ACT-3D确保没有一本手册,您可以使用Lumion3.0?好奇的重新设计的环境设置?迫不及待地想看到新的“照片模式”和导出选项?
ACT-3D会让你知道这个博客上的所有内容。你下一次见!
2、Better horizon and water
  更好的视野和水
Here is one more nice screenshot of the sky. Also notice how the new sky meets the ocean at the horizon. New fog functions improve the overall look of the horizon.
这里是一个更漂亮的屏幕截图的天空。还要注意如何在新的天空符合海洋在地平线上。新的雾功能,改善整体外观的地平线上。
3、
Lumion 3.0 improves rendering of the sky and horizon
Lumion 3.0提高渲染的天空和地平线
Lumion 2.5 uses textures for wave patterns on water. The disadvantage of this method are artificial repetition patterns when at a distance. For Lumion 3.0 we decided to get rid of this effect by replacing textures with carefully selected mathematical functions.
Lumion 2.5使用在水面上的波浪纹的纹理。这种方法的缺点是人工的重复图形时,在距离。Lumion 3.0,我们决定摆脱这种影响通过更换纹理精心挑选的数学函数。
4、Lumion 3.0 clouds
   Lumion 3.0云
Before we dive into details about user interface improvements and other new features we would like to give you a preview of the spectaculair new 3D clouds. The images speak for themselves so watch the movie and see how Lumion 3.0 improves on cloud rendering.
在我们深入细节对用户界面的改进等新功能,我们想给你一个预览的spectaculair新的3D云。形象代言为自己看电影和看Lumion 3.0如何提高云的渲染。
5、Lumion 3.0 sky system
   Lumion 3.0天空系统
As a warm up we have some excellent sky screenshots for you.
Lumion was already known for it’s excellent skies but with Lumion 3.0 we wanted to make sure the software remains the best in the industry in this area.
Take a look for yourself to see the amazing realism and detail. This is just a small preview of things to come.
The new Lumion will even be able to cast cloud shadows. For the first time you will be able to fly in between clouds and see them wrap around mountains. More on that subject later!
作为热身,我们有一些优秀的天空为你的屏幕截图。
Lumion已经知道它的优良的天空,但Lumion 3.0,我们要确保软件在这方面仍然是行业中的佼佼者。
看一看自己看到了惊人的真实感和细节。这仅仅是一个小的预览的东西来。
新Lumion甚至可以投下云影。这是第一次,您将能在云层间飞行,环绕山。在这个问题上!
6、Lumion 3.0 upgrade prices revealed
   Lumion 3.0升级价格发行
The Lumion 3.0 release is scheduled for November 2012. Current lumion 2 license holders can benefit from attractive early-bird discounts!
Check this page for upgrade information and pricing.
定于2012年11月Lumion 3.0版本。当前lumion 2许可证持有人可以受益于有吸引力的早期鸟类的折扣!升级信息和价格,请选中此页
Enscape官方许可证团购
忠实粉丝
4806137 2012-9-20 09:57:30
更新速度真快啊~~~~
希望有XX版{:soso_e113:}
yrxjjj 2012-9-20 10:38:55
体积云比较给力!
sujc0416 2012-9-20 18:02:25
反射 和闪烁 问题才是最值得解决的问题!
kuangji 2012-9-20 21:01:43
好过比原来更真实了,期待!!
flamsky 2012-9-21 10:49:17
视点拉远后的重面问题什么时候解决--
et0920 2012-9-22 11:52:33
GOOG THANKS
peridianer 2012-10-3 13:47:42
少说了一点,3.0加了不少的图块,尤其是坐着的和趴着的人,姿态更丰富了!
39
blackbear 2012-10-5 12:03:28
多谢楼主了,看起来容易多了。
Early bird在英语中是指早起的人,最早到的人,这句中可以理解为现在就买的人,会有比较大的折扣。
tb555 2012-10-5 20:06:22
感谢分享!感谢分享!感谢分享!感谢分享!感谢分享!
23
yclilabc 2012-10-5 21:23:23
好期待啊~
shuidaop 2012-10-9 14:22:22
期待的同时希望尽快有破解喽~
Aykan 2012-10-9 15:23:42
改进反射折射的机制更加重要!
至今为止,玻璃,镜子,磨砂玻璃一类的反射和折射问题才是最重要的,背景云层什么并不能作为主体
章鱼OctopusChen 2012-10-10 02:00:15
中国人民又要开始劳动了!期待11月!更期待11月后的XX!
starplex 2012-10-16 17:30:06
这翻译的,太棒了
27
热心助人奖新秀奖宝石收藏家积极讨论奖
shukansi 2012-10-17 12:31:56
这个更新速度差不多可以赶上游戏的的水平了
38
宝石收藏家忠实粉丝积极讨论奖
山東男孩 2012-10-17 18:34:08
有前景的軟體就有錢景了
dmwq01 2012-11-11 17:08:55
这体积云很期待的说
2012龙年春节团拜纪念邮积极讨论奖
huweihao 2012-11-11 21:21:41
体积云比较给力!
23
2012龙年春节团拜纪念邮积极讨论奖
文若3 2012-12-11 10:33:10
哇塞,云好看~
12下一页
夷陵墨香
