禁止发言
sufang0183h 2012-1-7 11:25:43
torrent文件Lumion 2终极组建2便携式3.27 GB的RAR文件没有密码,请种子/ 股无需安装Lumion 2 2建立,这是便携版!1复制文件夹“Lumion 2组建2”根目录C :2复制文件夹“Lumion 2”到“:\用户\用户名\文件3请确保该文件mylumion.ppp的属性是只读(突出显示文件并右键点击,隐藏只读的属性和右键单击-检查读的变化只有4开始Lumion之前,所有的Lumion互联网连接块永久!(防火墙)所有学分去Xuanbach1958bk,NKWeilan Black_h这是我第一次,所以要很容易,如果有什么不顺心,我会尽力帮助,请随时有积极的批评,什么时候可以做一些事情更好的:-)我不知道如何添加torrent文件看中形象,所以我上传种子文件到超过20万PDF。希望这个工程。好运。Lumion 2终极组建2便携式3.27 GB,RAR文件没有密码
Copypasta from: http://forum.cgpersia.com/f13/lu ... 5550/#ixzz1ijt2iBgR
热心助人奖新秀奖
uuonegirl 2012-1-7 11:25:45
额。。破解方法来说。现在我的帖子的方法就够用了。也比较稳定
禁止发言
sufang0183h 2012-1-7 11:31:02
禁止发言
sufang0183h 2012-1-7 11:37:34
这是他的原文:Torrent File
Lumion 2 Ultimate Build 2 Portable
3.27 GB, rar file
NO password
Please seed/share
No need to install Lumion 2 build 2, this is the portable version!
1 Copy folder "Lumion 2 Build 2" to root c:
2 Copy folder "Lumion 2" to ":\Users\your username\Documents
3 Make sure that the file mylumion.ppp attributes is change to read only ( highlight the file and right click-, properties and right click from hidden to read only - check read only
4 Before starting Lumion, block all Lumion internet connections permanently! (with your firewall)
All credits go to
Xuanbach1958bk, NKWeilan & Black_h
This is my first time so take it easy. If anything goes wrong I will try to help.
Please feel free to have positive critics when anything can be done better :-)
I don't know how to add a fancy image of a torrent file so I uploaded the torrent file to Mediafire. Hope this works.
Good Luck.
3.27 GB, rar file
NO password
Copypasta from: http://forum.cgpersia.com/f13/lu ... 5550/#ixzz1ijvuiegN
禁止发言
sufang0183h 2012-1-7 11:42:03
禁止发言
sufang0183h 2012-1-7 11:45:17
原文是:
________________________________________
Torrent File
3.27 GB, rar file
NO password
Please seed/share
All credits go to
Good Luck.
3.27 GB, rar file
NO password
禁止发言
sufang0183h 2012-1-7 11:47:40
大哥您能够帮着翻译一下吗?我一直没有弄明白。
热心助人奖新秀奖
uuonegirl 2012-1-7 12:51:53
好的。可以
他这个说的就是3.27g大小的解压包。是绿色版
No need to install Lumion 2 build 2, this is the portable version!.
不需要安装lumion2b2,这是绿色解压版
1复制lumion 2 b2文件夹到c盘根目录
(经我测试,该目录可以放在非系统盘)
2复制lumion 2文件夹到c:\Users\your username\Documents
(这一步是必须的,也就是我的文档的目录)
3 确保ppp文件属性改为只读,右键文件——属性——勾选“只读”——确定
(同样这步也是非常重要)
4 在运行lumion之前,利用防火墙关闭lumion所有的网络访问
(这步可以通过修改host文件达到目的)
通过以上对Xuanbach1985bk大大的绿色版的破解方法的分析,我的总结教程应该是最完整的,大家可以直接参考
热心助人奖新秀奖
uuonegirl 2012-1-7 13:01:46
有网友发现的我帖子教程有漏掉的东西,特地补上。感谢我是分隔线  109687170这位朋友提醒
加入到1楼教程中第一步最后部分,也就是第二步之前,注意~!
查尔斯——rewrite——import——xml文件
(, 下载次数: 2)
1.tools——rewrite——勾选enable rewrite——import——选择xml目录并选择xml文件
(, 下载次数: 0)
2.该图示中是尾号为13的xml,我的链接中是尾号14的xml,一样用。注意
(, 下载次数: 0)
(, 下载次数: 0)
menlesher 2012-1-7 13:25:44
试了 完美破解~~多谢uu大神啦~~{:soso_e154:}
xmf0912 2012-1-7 15:44:47
我看之前以犀利糊涂的搞破了,没有复制那个文件到我的文档
反正看起来很麻烦,等我孙子长大了,我让他写个破解文件,让lum闹得
xmf0912 2012-1-7 15:46:14
红宝石用户A
icanfly123 2012-1-7 16:19:38
JAVA的那个破解步骤 图片模糊 看不到要点哪里。。可以具体说一下吗。谢谢了{:soso_e113:}
泥猴子 2012-1-7 16:55:36
楼主 我运行 EXE提示 不兼容 ,W7 32位系统 能帮解决么?
手绘蓝图 2012-1-7 17:04:54
为什么下载不了呢
热心助人奖新秀奖
uuonegirl 2012-1-7 17:11:39
反正看起来很麻烦,等我孙子长大了,我让他写个 ...
现在我在45楼有详解
热心助人奖新秀奖
uuonegirl 2012-1-7 17:12:20
下载官方安装版,也就是帖子1楼第二个链接
热心助人奖新秀奖
uuonegirl 2012-1-7 17:13:02
icanfly123 发表于 2012-1-7 16:19
JAVA的那个破解步骤 图片模糊 看不到要点哪里。。可以具体说一下吗。谢谢了 ...
现在我在45楼有详解
热心助人奖新秀奖
uuonegirl 2012-1-7 17:13:34
手绘蓝图 发表于 2012-1-7 17:04
为什么下载不了呢
哪个下载不了,请说清楚,我好换链接
金色☆年华 2012-1-7 17:36:03
我是用安装版的,电脑是32位win7,安装好软件以后,我的文档里面没有lumion2 这个文件夹,但是我以前装的lumion1的 lumion的文件夹 在里面的,于是我就把楼主提供的lumion2文件夹复制进去,按照步骤操作,发现不能破解~
uuonegirl
