置顶帖下载
Enscape-Setup-2.4.1.913-g903f869
2018-12-12
Textured reflections
When you set render quality to Ultra you will see textures in your off-screen reflections. Previously, the surfaces were uniformly colored.
渲染质量设置最高时镜面反射可获得正确的材质贴图显示
Improved outlines
Outlines no longer scale with your resolution. This means that with a higher resolution, the outlines will be thicker in terms of pixels.
Also you won't see outlines around grass and vegetation objects anymore.
提升的线框渲染效果,不会随着画面分辨率提高而变细,草地和自带植物不再有边框效果
Tags in AssetLibrary
You can use tags to find the asset you are looking for much faster.
自带物件库添加了标签
Safeframe Indicator
Once you enable this setting the first command to render an image activates the safeframe and the second command actually starts rendering.
新增一个安全框?的激活按钮,激活以后点击渲染图像不会开始渲染,需要点第二次才会开始(防止误操作???黑人问号)
Shadow / Highlight Slider
Similar to Photoshop, you can now tune the tonemapping via two sliders to add or remove brightness at certain regions.
取消自动对比度以后,会出现两个滑竿,一个调节高光亮度一个调节阴影亮度,对于阴影很黑的情况下,挺有用
ENSCAPE超级讲吧原创教程
Enscape官方许可证团购
xmf0596 2018-12-13 16:56:09
这j2软件被国内部分人垄断,整些月经版,月月..........
点评
正版真心不贵  发表于 2018-12-13 17:23
周星星同学 2018-12-13 22:59:22
终于修复了镜面反射。感谢分享!!
老方2012 2019-1-15 12:36:12
终于能显示镜面反射了!
tas_1985
