到目前为止,Thea V2已经发布了4个更新版本:RV759.1802,;RV766.1803 ;RV773.1803,;RV780.1805。前两个版本BUG较多,尤其是安装后会出现无法运行或崩溃的现象,需要打补丁方可运行。RV773.1803修复了安装后无法运行的BUG,可以正常安装运行而无需打补丁了。最新的更新版本RV780.1805又修复了一些新的BUG,建议想玩的同学安装最新版本RV780.1805。
这是RV773.1803修复的补丁:
  • Thea Browser: "Apply to edited Thea material" right click option for materials. Material editor has to be opened for the option to appear.
  • Material Editor: option to load .mat.pack file. The material is unpacked in a folder called same as the material file.
  • Batch Render temporarily disables Optix and NLM when rendering, but saves denoised output (Optix,NLM)
  • Batch Render warns when output will overwrite files
  • Batch Render: "Save All Channels" saves NLM denoised output without denoising channels
  • PSD output doesn't include NLM specialized denoising channels
  • All texture parameters are shown for SketchUp texture in Editor
  • Invisible Emitter doesn't cast "shadow" when close to other object
  • Updated Italian, Japanese and French translations
  • Fixed issue with Clipping resetting texture properties when toggling Hard/Soft option
  • Fix for mat.pack not containing a preview of a material
  • Fixed issue with SketchUp Images not being exported. This should also fix issue with Archvision RPC content not being rendered.
  • Fixed issue in Chinese translation causing crash of the plugin
  • Glass Layer: Subsequent editing of Reflection doesn't crash any more
  • Glass Layer: Reflections are set to White for a new layer
  • Glass Layer : "Absorption Color" is properly named when properties are being displayed (it was "Absorption (1/m)" before)
  • Glass Layer : Ensured that Transmittance is White when absorption is being used
  • Bitmap parameters are no longer shown after selecting an empty bitmap texture slot
  • License Wizard is being opened correctly. It doesn't require other Thea plugin window to be opened first
  • Win: removed flickering on resizing of tabs
这是最新版RV780.1805修复的补丁:
  • Win: Optix 5.1.0 used (There is no update from Nvidia for Mac)
  • Upgraded to CUDA 9.2.148 - fixes issue with new drivers(for example 1080 not recognized)
  • New: 'Extensions/Thea Render/Tools/Install Library' to install lib.thea file
  • Fixed issue with access to Online materials repository through Thea Browser
  • SU2018 - Fixed black material after renaming it in SketchUp (workaround for a bug in SkechUp 2018)
  • Fixed visibility/shadow issues with Emiter and standard geometry
  • Made Texture Selector keep all parameters of BitmapTexture when a new bitmap is selected
  • Fix: Material Presets: Black preview could appear when something has been changed in currently edited material using SketchUp texture
  • Fix: Material Presets: Bitmap Texture path is shown now and applied in IR correctly when changed
  • Fixed native characters issue in a material name. Material couldn't be edited and was rendering black.
  • Material changes are synced between SketchUp and Thea including Undo operations (plase note that it may take 3 undo's to revert a single material edit)
  • SketchUp closes correctly despite rendering is paused now. It was getting "frozen" before.
  • Material Presets: "Remove SketchUp" is not shown for Color
  • Fix for server license on Mac
  • Splash screen shows version number now
  • "About" uses splash screen now
  • Translations has been updated
  • Stereoscopic translation for Presto is now computed on the fly (means it is faster)
  • Adjusting camera position depending on the direction for cylindrical and spherical cameras, so as to get correct stereoscopic effect for panoramas.
  • MAC Fixed negative saturation resulting in artefacts for certain colors
  • Nlm/Optix: Exr/hdr files are now saved with gamma correction (Manolis)
  • Nlm: Fixed border around image issue (affects CPU/OpenCL) (Manolis)
  • Optix: catching possible exceptions in shutdown
  • Added functionality to create, install and load header of library files (lib.thea) in SDK.
  • Respecting now visibility flags for infinite plane in Presto.
  • Regression bug fix for shadow and variance channel in Presto when they are both enabled.
  • Standard Display uses CPU when GPU fails due to running out of memory (GPU -> Multithreaded CPU -> Single threaded) (Christos)
附上RV780.1805下载地址:
补充内容 (2018-9-30 11:10):
此版本已不是最新版本了,最新版本请移步到下边的链接地址:
http://www.sketchupbar.com/forum ... read&tid=349607
Enscape官方许可证团购
snailzy1978 2018-9-5 11:21:28
Luis006 2018-9-5 12:37:16
谢谢分享
YGYL2 2018-9-5 12:50:22
看看                                                      .
井蛙新月 2018-9-6 13:24:33
看看这个版本如何
gyong163 2018-9-6 14:34:24
不错,看一看
54970430 2018-9-6 17:57:45
高级版么。
ommusic 2018-9-7 09:21:31
谢谢分享
youto 2018-9-7 10:40:10
谢谢分享
用双脚走路 2018-9-7 11:47:39
找了好久,终于找到。
98
Rank: 10Rank: 10Rank: 10
sm501212 2018-9-8 03:18:30
為了更好!!更新版本是必須的!謝謝!
22
guaguazi 2018-9-8 11:31:54
fenxiang
LWDJ 2018-9-8 16:42:21
TheaRender易用性强,但也是BUG不断,总得想法绕道,v2网络渲染总连不上,所以一直在用v1.5版,楼主功德无量,再下来试试。
默云 2018-9-8 17:32:09
谢谢分享、、、
12
忠实粉丝积极讨论奖
handyman 2018-9-8 21:11:36
謝謝分享
345346732 2018-9-11 09:33:05
下载下载 试试
25
sksf 2018-9-11 21:36:33
谢谢分享
iCom 2018-9-30 02:07:16
不知道有没有MAC版?谢谢
bb6
bb6 2018-9-30 09:01:30
谢谢分享
casino999 2018-9-30 09:02:00
看看阿奎那看那看那看看看看看
12下一页
zwendou
